Hi i tried to add subtitles in a movie in a .mpeg file with virtual dub and tmpenc, but when tried to open the .vdr file, i recieved the message that this fil is not supported, what can i do to make this file readable?
Search for a file called msvcr70.dll and place it in your Windows/system32 directory. If it doesn't work then, you may need to alter the VFAPI plugin priority settings. I think it is the Directshow multimedia filereader one(?)
Can TMPGEnc 4.7.7.307 XPress support output 5.1 Channels???
By JackyWang in forum DVD RippingReplies: 2Last Post: 17th Apr 2011, 22:37 -
Does Tmpgenc Authoring works 4 support motion background menus?
By perfection in forum Authoring (DVD)Replies: 1Last Post: 10th Mar 2011, 02:35 -
Tmpgenc Xpress 4: I Don't Want To Resize
By Tom Saurus in forum Video ConversionReplies: 17Last Post: 16th Nov 2009, 14:18 -
Only TMPGenc Support .vdr
By arturjose in forum Video ConversionReplies: 1Last Post: 15th Apr 2008, 23:04 -
After reinstall of OS etc, Tmpgenc encoder can't support avi media files
By AORMan in forum Video ConversionReplies: 15Last Post: 2nd Feb 2008, 10:36
