I use Sony DV cam directly connected to Sony satelite receiver record to film then
download to harddrive via firewire. Use wndos movie maker on XP system to create avi file. Excellent quality avi file
huge but good. Then I encode with TMPGEnc quality starts out good but
the audio gets out of sync towards the end. The larger the file the more out of sync it gets. Is there a way to fix this other
than making a bunch of small files encoding and splicing back together. I'm
new at this so apologies if this is a dumb question. Tried searching on audio sync
but too many hits to sort through. ANY advice appreciated.
I looked all over for this detect scene change and could't find it I'm using
the latest version 2.56 -
From the main screen, choose SETTINGS at the bottom, then open the tab 'GOP Structure'
Maybe a little better but the audio is still
slightly ahead of the video 1 hour into the movie. Goin to try seperating the audio from the avi file with virtualDub and then remixing with TMPGEnc -
I had the same problem and never found a solution.
I use DVD2SVCD now, no problems any more.
I don't know if this helps since you're captering from camera.
Sync audio starts-ok but near end 1 sec lag H.264/MPEG-4 AVC AAC LC
By JoeBolden in forum Video ConversionReplies: 6Last Post: 7th Jan 2010, 14:31 -
TMPGEnc DVD Author 3 gradually loses audio sync
By timmus in forum Authoring (DVD)Replies: 1Last Post: 6th May 2009, 17:24 -
Tmpgenc 3 audio video out of sync before encode
By marioval in forum Authoring (DVD)Replies: 8Last Post: 30th Jan 2008, 14:07 -
audio stops way before end of converted movie and is out of sync
By jboyd in forum ffmpegX general discussionReplies: 11Last Post: 17th Dec 2007, 05:12 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 14:10
