I have been Using TMPGEnc- to convert AVI to MPGE1 files then combine the two MPGE files to One MPGE1 file, Author it then Burn it with Nero.
But I have been having problems with the DVD-Movie pausing & skipping, also the clarity isnt to good, Like the Coversion from AVI to MPGE wasnt good or smooth... You can see blocks of Data in the Background of movie..........
QUESTION#1
WHAT is the BEST TOOL to Convert AVI Files to MPG?
#2
What Templates do you use to get better quality
#3
Is MPGE2 better quailty then mpg2 when convert from avi to DVD?
Could someone help a COnfuse SOUL!
JayDot~..........
QUESTION#1
ANSWER#1
Your using it.
Q#2
A#2
Depends on what you intend to do with it. Since you say MPG1, most likely you're interested in VCD. The blockyness is caused by a too low bit rate. When a great deal of action occurs, it sacrifices quality to maintain framerate. I'd suggest creating your own template with a higher bit rate if you just intend to leave it as an MPG file and not burn it to VCD. VCD files (MPEG1) need to have that constant bit rate, so you can't do much about it if that's your intention. Try SVCD.
Q#3
A#3
Given that DVDs are MPEG2, I'd have to say yes.
MPEG2 supports VBR which can greatly enhance quality, at the cost of extra (sometimes 3 times more) encoding time
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Need Help Finding Camcorder & Software to Win Soul Mate Back
By gbooth in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2008, 13:25 -
Still confused on upconverting
By glp103 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2008, 16:42 -
resizing, I'm confused!!!
By nalooti in forum Video ConversionReplies: 5Last Post: 19th Nov 2007, 08:14 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 12:42
