Hi all:
I'm having troble trying to write my project with spruceup..I follow the tutorial from ".dvd2dvdr.com" and the one on the Authoring section here ...I try to write direcly to my DVR-A04 and I get error "PAL/NTSC Video format mismatch with project setting"...I also try to output to disc image and I get error "File extention should be .IMG"...I follow this tutorial to the "T"...Everthing went fine till this point...Can someone check this tutorial and let me know if is allright or if i'm doing something wrong!!!!!!!!.....thank you all!!!
Never done any of this, so don't have a clue what you are talking about, however its telling you "PAL/NTSC" miss match, are you using a PAL mpeg and trying to make a NTSC disk, or the other way around ?
You must set your project up in Spruce, one of the options is PAL or NTSC. Make sure you create a new project, set it to the region and that will stop your mismatch problem.
With regards to the other problem, Spruce up is telling you that the extension for saving an image file is .img.TOMMO -
thanks for replys....
O.k this is where i stand now!!...I re-did my projet over and made sure I had the right settins...I now have been able to start the compiling process trying to write directly to a dvd-r but I get error "CD-R/DVD-R write failed"after the process its over.......When I try to export to disc image "with the correct extension .img", I get the compiling process started and when it finishes it give me error "process completed succesfully"????????..but it does not write the image.....I going crazy here!!!!!!
Problems exporting in Avidemux
By GSK in forum Video ConversionReplies: 5Last Post: 14th Aug 2010, 15:44 -
Problems Exporting Widescreen 16:9
By Funky Monk in forum EditingReplies: 3Last Post: 12th Sep 2009, 12:13 -
Problems writing with nero vision express 3
By tatester in forum Authoring (DVD)Replies: 3Last Post: 11th Feb 2009, 17:38 -
PPCS3 Exporting to 'Movie', Side Black Bar Problems
By joepurple in forum Newbie / General discussionsReplies: 0Last Post: 13th Jun 2008, 19:15 -
Exporting HDV
By adanchev in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 08:44
