  1. I am trying to burn some VCDs on Nero 5.0 but the audio is out of sync can anyone help me?
  2. go and download tmpgenc and the related info on authoring vcd, it will help ya
  3. I capture and create an avi file for DV camera avi file is geat on computer but when I encode with TMPGEnc mpg file
    starts out good but the closer to the end of the file I get the more out of sync audio and video are sound and picture are good just out of sync, Please Help!
  4. Banned
    Jun 2001
    UK
    Lip sync may be fixed in Vdub
    Audio > full processing mode
    Audio > Conversion > 44.1Khz
    SAVE WAV
    TMPGEnc
    Browse for AVI
    Browse for WAV (As saved previously)
  5. I had the same problem with a vcd the other day...however if has only happened once so far. The movie played fine until I got about 10 minutes towards the end of the film and then I was behind by about a mintue or so.
    Greg
  6. Banned
    Jun 2001
    UK
    Greg
    Then I guess 10 Min before the end it has bad frames.
  7. I should mention that the audio is always ahead of the video. And I'm talking less than a second after an hour. Also, I'm checking it with RealPlayer and moving the slider towards the end of the movie.
  8. Banned
    Jun 2001
    UK
    You may be dropping frames during capture, saving out the audio from a movie that has bad frames wont help.
    Playback of anything on a computer can not always show up problems, sometimes you need to view it in an editor, and sometimes frame by frame to spot problems.
