  1. Hi all,
    I'm using Media Studio Pro 6.0 with all recent patches applied.
    System and PC ok. Win 98 ok.
    All functions working fine, but...
    If I insert a mpeg file (even one created with Media studio) at the Timeline (filmstrip mode activatedat the timeline display) I just see a black strip, not the scenes as I can see with a AVI filmstrip.
    It only occurs with mpeg files.
    This way, I cannot edit mpeg files at Media Studio.
    Can someone give me some light at the end of the tunnel ?
    Thanks a lot for your attention
    Chris Fabbri
  2. as it is a new format for MSpro, did you change the timeline setup preview??
    "Oo"?
    P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo
  3. Yes.
    I didn't work...
  4. Sorry,
    Yes, I did it, but it does not work anyway...
    Chris
  5. well, i don,t know how much rams or cpu you have but defrag before using MSpro and Large files.
    also,,check at Ulead site for patches and tweaks for different video cards and bugs.....
    "OO"
