Hello. Do you know where I can download Microsoft MPEG-4 v2 codec? Thanks.
Try this link:
http://codeczone.virtualave.net/fixes.htm#CODECS -
Also make sure that if you are running a windows machine that you download the MediaPlayer 7.1 from microsoft. It will give you even more support then just the codec alone will.
I didn't say that media player seven was the best program to use, but it will provide the support that you will need for some of the DivX files on the net. Once you install media player seven, you "should" (microsoft speak) be able to use TMPGEnc and other programs to play, convert, edit.... the files. I personally use ATI File player for most of the movies I watch, but it would not play some DivX files untill I went to MP7.1.
Advice on which codec pack to download.
By prankstare in forum Newbie / General discussionsReplies: 26Last Post: 8th Sep 2009, 09:13 -
which codec to download to play DVD on wmp 10 ?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 2nd Oct 2007, 01:28 -
Need to download a YUY/DIB Codec
By vegasarian in forum Newbie / General discussionsReplies: 9Last Post: 23rd May 2007, 11:02 -
The Vital Message - General Fiction, download ebooks, free download, The
By spacek77u in forum DVD RippingReplies: 1Last Post: 14th May 2007, 02:29
