how many hours of VCD Quality can a DVD-R & DVD+R hold? & any dvd burner out there is capable of using all the formats??? -r +r???
Well I have don't have a dvd burner but understand that blank media will hold about 4.5gb. If an standard VCD takes @600mb for 1 hour, then my guestimate is that you could get about 7.5(+/-) hours of video in VCD (MPEG1, 1150kps) format on a DVD-/+R.
I have no idea of what the compatibility issues would be.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
On the video side VCD standard MPEG video is within the DVD specifications. It's the audio that isn't. The DVD spec calls for audio sampled at either 48 or 96Khz whereas VCD is strictly 44.1khz. You would need to demux your MPEG files to seperate video and audio streams, then re-encode the audio to 48Khz.
Works fine for me. -
With some Templates that are on Kwag's site www.kvcd.net I can get up to 3 movies (2 hr each on one DVD-R), this depends on the movie, a lot of action would give me two on one DVD-R, I use DVDiT to do the work, it will convert the aduio for me. All these are in SVCD format. So just take a look at the templates on the site, see what they can do, if you don't like them you loose nothing but a little time.
Aloha
Bud
Help!! Can you create a DVD for both DVD player and hold data files for PC?
By musicalsolutions in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2010, 07:32 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 22:23 -
2:40 hours in a DVD 4.7 Will the quality fall?
By X_Splinter in forum Authoring (DVD)Replies: 6Last Post: 28th Jan 2008, 08:11 -
6 hours of good quality video on dvd
By gameroftheuk in forum Authoring (DVD)Replies: 1Last Post: 30th Aug 2007, 02:59 -
Editing Sections of DVD's to a new DVD without losing quality & keeping
By notpinky in forum DVD RippingReplies: 3Last Post: 18th Jul 2007, 15:51
