I was wondering why sometimes when I connect my DVD player directly into my VCR and record the DVD, the movie will mute and discolour for about 10 seconds then go back to normal, then discolour, then normal and so on throughout the entire thing. This only happens with certain ones though. Ones that did work include Swordfish, rush Hour 2, and Billand teds excellent adventure. Ones that did not work include Planet of the Apes, Ace Ventura: When Nature Calls and SNL:Best of Dana Carvey. Any insight on why this happens or better yet how to fix it would be much appreciated. Thanks.
This is Macrovision copy protection. It is designed to prevent copying from DVD to VHS. There are hardware boxes you can buy to bypass this and DVD Ripping can remove it. Otherwise you are stuck.
Just go to circuit city and buy a SIMA digital copymaster they work great!!!!!!!!!!!!!!!!!!!!!
J&R has a mighty good price:
http://www.jandr.com/JRProductPage.process?Merchant_Id=1&Section_Id=1395&Product_Id=21757&showcase=tAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Sima are great (I have one myself for VHS) but they are not what I'd
use to overcome DVD macrovision. The best thing is to get a macrovision free DVD player.
Different Sima models handle
different levels of macrovison. Non are perfect in all cases as
they have to filter the signal after macrovision is enabled.
A macrovision free DVD player will simply bypass macrovision
completely, resulting in a better picture all of the time.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
