I've just captured my first 352X480 using the Radeon and it was outstanding. The video sharpness was unbelievable. Yet with all this celebration I found one flaw. My Apex played the file fine, but the Sony had a problem with the resolution and played only a portion of the screen. The resolution made it difficult for the Sony but not the Apex. I was wondering does it make sense to continue to record using a resolution that might not work in many DVDs? What do you think?
Are you talking about SVCD or a DVD-R(W) ?
A dvd player that fails to show a 352x480 movie from a DVD-R shouldn't be called that way anymore.
cya
Sony players are known to be very bad at handling
non-standard video formats.
The most popular brands aroung here seem to be Apex
and Pioneer-- I'm pretty sure that both of these brands
can play your format. -
352x480 is a supported resolution on DVD (burned DVD should work; miniDVD if your player can handle DVD content on a CD-R/W). It is not an officially supported resolution in SVCD, although most SVCD players support another format called Chao-Ji Video Disc, whose basic resolution is 352x480/576.
I have an Apex and it does the job well, The Sony sucks..and doesn't play SVCD. I was wondering if the non standard 352x480 would present problems in the future with newer models of DVD players. I don't want to create disks that will not be playerable in a few months or years.
from dvddemystified.com:
Allowable picture resolutions are:
MPEG-2, 525/60 (NTSC): 720x480, 704x480, 352x480
MPEG-2, 625/50 (PAL): 720x576, 704x576, 352x576
MPEG-1, 525/60 (NTSC): 352x240
MPEG-1, 625/50 (PAL): 352x288
352x480 is standard for a DVD.
352x480 is not standard for a SVCD (AFAIK).
cya
Converting 720x480 to 352x480
By Regor21 in forum Video ConversionReplies: 8Last Post: 9th Mar 2011, 11:34 -
Bitrate 720x480 vs 352x480 concept question
By CaZeek in forum Capturing and VCRReplies: 15Last Post: 8th Oct 2010, 13:08 -
How to patch 352x480 MPEG-2 to 720x480
By moxiecat in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 14:43 -
720x480 or 352x480 ?
By StoneColdWhat in forum Video ConversionReplies: 7Last Post: 7th Aug 2009, 09:16 -
352x480 Half D1 Mpeg2 to Divx - How do I keep proper aspect ratio (40:33)?
By stizz in forum MacReplies: 16Last Post: 8th Feb 2008, 02:24
