Hi guys,
Im currently authoring SVCDs, and I wanted to know which Silver color DVD players can play SVCD disks back flawlessly (Fully complient SVCDs). In addition to flawless playback, does anyone have a silver color DVD player which also correctly brakes down SVCDs two audio channels so that in addition to two stereo streams you can play Left speaker only, or Right speaker only (Eg, for Chinese movies)?
If anyone has a Silver color DVD player which can do this, I would greatly appreciate it if you could post your manufacture, model number, price you paid for it as well as any other general comments/tips/Authoring Compatability notes.
Thanks, I really appreciate it!
Results 1 to 9 of 9
Yep, I have the Pioneer as well and I've been dead chuffed with it... plays pretty much anything you throw at it
Very nice player indeed.
I got a FINLUX, cheap player, only 149 euro's a.t.m ! Plays all formats, mp3,vcd,svcd,dvd,cdaudio etc. Cool player!
Hey guys,
Actualy I have been thinking about the Pioneer DV-444, however when I author my SVCD disks, I use Tmpgenc i (SVCD template). I follow SVCD specs for bitrate, and other features. The problem is, on my friends DV-444, I noted that some movies started to freeze, or blow chunky blocks on the screen. Im unsure what the cause is, but It would really be bad if the unit doesn't play standard SVCDs because all my CDs are up to standards and I don't want to redo them.
FYI, I have been told the max bitrate is slighty under SVCD specs? Ether than, or its the audio emphesis option which needs to be changed to fix the problem? -
About Apex brands, I have seen most (if not all) don't allow multi-channel audio selection. You can't take one of the SVCD tracks and do Left only or Right only.
Originally Posted by Trenton_Net
Videobitrate: 2496
Audiobitrate: 224
When quality is an issue (edited DV-fragments for example) I use CBR@2496 or the following VBR specs:
min: 1200-1800 (just try
avg: 2200
max: 2496
Time is no issue, so I batch-encode 1 CBR, and 2 or 3 VBR with different min-bitrates -
Hey Trenton
If you search hard enough through this forum you should find my thread regarding problems with the DV-444 and TMPGenc.
Basically, I discovered (with much help from these guys) that TMPGenc doesn't encode to SVCD 'standard' even with the SVCD template.
It took me a long time to find the best TMPGenc settings but I got there in the end.
Now I make superb quality SVCDs with no jumps, lockups, large block artifacts etc etc.
You're more than welcome to try my template. Email me if you want it.
Hope this helps!
Sue xxx
Weird color saturation when connecting dvd player to tv with hdmi cable
By bigmack3000 in forum DVD & Blu-ray PlayersReplies: 22Last Post: 15th Sep 2014, 11:20 -
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Calling all DVD Lab pro experts
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 18th Jul 2010, 03:56 -
simple question for experienced DVD player owners
By asmodeus718 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2010, 22:02 -
Owners Manual of Daewoo DVD S151dvd player
By lambuhere1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Jul 2007, 06:15
