I have been using tmpegenc with no problems converting divx movies into vcds and svcds. I went to convert an .avi to mpeg vcd and it wont show the video in the source range. It just stays blank but shows the audio. I havent changed anything and i figured maybe i had an off .avi file so i used one of avi movies i had on disc that i had already converted with tmpeg with no problems and iot wont read that either. I also downloaded new version 2.56 hoping that the new version wiuld help thinking that my copy had become corrupt. But still having the same problem any help would be appreciated. tia for your time. shawn hep
Go to Options -> Environmental Settings -> VFAPI Settings. Right click on the DirectShow drivers and increase their priority until the picture returns. I have had to turn this off for some frameserving applications and if you don't set them back to a priority, there will be no picture.
You will find a description to fix the problem here:
http://www.homepagemodules.de/board/topic.php?&board=1213&id=46801&forum=1860 -
i had the same problem with virtualdub & TMPGenc & it was driving me crazy. All I had to do was follow the advice kindly given by Ostaf (see my posting) that is to re-register the codecs cos for some reason the programs couldn`t find them in the registry.
Good Luck
Software to show frames (in specific frame range and in groups)?
By therock003 in forum Newbie / General discussionsReplies: 0Last Post: 27th Dec 2011, 12:06 -
Help, AVEr TV combo pcie wont show video inputs?
By BoonDoggie in forum Capturing and VCRReplies: 7Last Post: 11th Jul 2011, 02:42 -
White Screen in TMPEGEnc 4.0
By barrylay in forum Video Streaming DownloadingReplies: 0Last Post: 1st May 2011, 15:09 -
WMP 11 XP avi wont play anymore
By axlefoley in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2008, 01:39 -
My DVD drive wont record Deul Layer anymore.
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 11th Jun 2007, 15:07
