I have a JVC DVl9800 DV NTSC camcorder, but this baby is NTSC. But I want to export it from computer to PAL tape.
Importing goes well, but when I convert the film to PAL, every fast element in the film, shows much horizontal stripes. I know that this is because of the change in size framerate and frequency. But there has to be a cheap way to convert between these formats, without using a high priced converter. Does anyone know if there is a software based program to convert files from 720x480/30fps/50Hz to 720x576/25fps/60Hz, without any stripes. And is this also possible in Analog and DV format?
Maurice Spees
Visualantis -
There is a way to do this but may not be the best.
Encode you NTSC DV video to MPG2 (or mpg1 for lower quality), burn it to SVCD(VCD), then play it on a DVD player such as apex500w, tape it using VCR. You have to have a DVD player supporting both PAL/NTSC output. -
Or you can encode the DV-avi to PAL MPG2, and play from you PC and tape it from your PC's TV output. No DVD player is needed.
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:40 -
Newbie : How to convert PAL into NTSC Format for Video Cassette Player
By kato2010 in forum Newbie / General discussionsReplies: 7Last Post: 11th Sep 2010, 11:40 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL aspect ratio 2.35 format to 16:9 NTSC
By chowa in forum Video ConversionReplies: 7Last Post: 2nd Feb 2008, 18:16 -
convert pal dvd to ntsc format?
By butt_crack in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2007, 00:26
