  1. I was wondering is there any possible way to rip a dvd without a dvd-rom drive?
    cause i got a regular cd-rom drive and a cd-writer
    Las Vegas
    no
  3. NO
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
    Jul 2001
    One Step From Hell
    YES........
    .............Just kidding. got ya. NO!!!!!
  5. damn that really sucks!
    thanks for the info
  6. Yes it s possible
    Hook up a settop DVD player to a video capture card, play the DVD on one side and record on the video capture card. If the capture card does not have macrovision enabled (like my Dazzle), you get very nice captures as a result, you can do SVCDs or VCDs very nicely.
    Cheers
  7. ..or get someone to copy the dvd to something like a laptop
    and then network it across to your machine.
    Some films on DVD can be
    bought on SVCD or VCD which will be readable on your computer.
    You do need at least a 200Mhz cpu to play them though and the
    quality will not be as good.
