    Italy
    well, that's it: i need a cutter better than tmpgenc, because it misses about 5-10 frames instead of what it writes into the "end frame" space.
  2. Do a board search for "frame-accurate cut".
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
