Can someone lead me to a guide or tell me STEP BY STEP on how to put a DivX movie on a DVD-R using a Pioneer A03?
You have to convert it to a DvD compatiable file first
Any tools I talk about you can download in the tools section
Load Vdub
--Load yer movie into it. Goto the Audio menu put it on Full processing mode. Then goto Audio-->Compression. Select no compression. next goto Audio-->Conversion select 48000hz
Goto File-->save wav. Save the wav someplace and close Vdub
Now load TMPGenc. Run the project wizard pick DvD- NTSC or Pal. Int he video part load the divx movie in the audio part load the wav file you jsut made. Hit next then hit other settings, goto advance tab and under Video Arrange Method scrolls down to Full Screen(Keep aspect ratio) Click ok, goto next, start encoding, take a nap, eat lunch come back in a few hours. When it's done you have a file you can burn to a DvD. -
Dont forget you have to author to DVD spec with a proggy like MyDvd or DVD workshop or it wont play in (almost) ANY standaloneWhen it's done you have a file you can burn to a DvD.
for more info take a look here:-
http://www.vcdhelp.com/tmpgencdvd.htm
and here
http://www.vcdhelp.com/author.htm -
I have 2 parts of a full movie. They are in DivX. Should i combine them first then use TmpGenc to make it a DVD file?
What program could i use to do this?? -
Use Virtual Dub to join your avi.'s. The guide is too your left. Click EDIT then go down to "how to join or cut avi" and below that it says "How to cut/join with Virtual Dub". That should tell you what to do.
HELp!!
I couldnt put to together because it said they had 2 different audio rates??
WAT??
HELP!!
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
