Hi, i heard that you can record up to 800Mb of data in a 80 minutes cd if you use mode 2 form 2.
I have tried Nero, Disc Juggler and Easy cd recorder, and none of them seem to have an option to choose mode 2 form 2.
Does anybody what i can do?
mode 2 is vcd/ svcd
Just think of it as if you were going to burn a music cd 80 minutes of music fits on a 80min/700mb cd-r. no matter if it is over the 700 mb it will still burn the 80 minutes of music.
Hope this helps
VD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
Elchef,
It is possible to burn up to 800 mb of any type of data on a cd with use of some special tools. In particular you need to get the Mode 2 CD maker, Mode2 CD Maker GUI and the Riff CD/XA Filters (they can be obtained at www.doom9.net) however this is not a good idea for a divx. Divx and most avis have no built in error correction. By burning as an XCD you strip out the CDs built in error detection/correction and stand a good chance of having the disk go bad. Other video format (i.e. ogg and mcf) do have built in error correction and can be safely burned in this format. You can give it a shot, but I do not recommend it. -
Burn your 800MB on a 99min. 850MB CD-R, that should solve your problem, 99min, CD-R's work fine for what I use them for.
Firstly, your burner needs to support 99 min CDR, mine does but will only burn upto 92 minutes. Secondly, your DVD player needs to be able to play these overburned discs. My DVD player will only play upto 88 minutes, then gets stuck in a loop. So although I have some 99 minute discs with a potential 19 extra minutes capacity, I can only use an extra 8 minutes.
Craig
Slow down the video to roughly fit with the audio?
By smd721 in forum EditingReplies: 4Last Post: 23rd Apr 2010, 05:55 -
Video won't fit on dvd
By chevyfever in forum Video ConversionReplies: 5Last Post: 6th Nov 2009, 07:50 -
Avi Video That will Fit a CD
By niteghost in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 09:21 -
Can I fit 5.3 GB video on a 4.7 GB DVD?
By better life in forum Authoring (DVD)Replies: 13Last Post: 16th Nov 2008, 20:42 -
video doesn't fit my TV screen
By hzgg2 in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2008, 06:56
