ive just bought my ge force two and whe i watch my movies on full screen on the tv the flicker and jump slightly making it look as if the lip sync is out . Is this a common problem with tv -out as i have just got rid of an m-peg card which was a little better or is there a way of improving the smooth play of my films
thanx in advance
keep up the good work
I had problems on my GF3 when I used a resolution of 800x600 for the desktop. Problem was solved when I used 640x480 desktop resolution on the TV output. Give it a try ... other than that, I don't know.
If you are playing a DVD or movie with macrovision and you connect your tv-out to a vcr before the signal goes to your TV it will do that or worse. Also if you have a tv-out on the television which is connected to an external device like a vcr it will also cause that problem even though you first connect to the TV.
I have a GE force2 mx400 and my normal monitor setting is 1024x768
When I play movies to the TV I find its much better if I change my primary monitor screen rez so that it is the same as the max clone signal going to the vcr/tv (800x600).
Check out info TVTOOL and possibly DVDIDLE they remove macrovision but also these apps stabilize the picture and remove the flicker.
3d movie has spilt screen I want it full screen please help.
By stadelbauer in forum Newbie / General discussionsReplies: 9Last Post: 18th Dec 2013, 17:46 -
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 19:40 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23
