I try to set the CUSTOM FORMAT to 480x480 and get a little error box saying "unsupported video format" error.
No matter which CUSTOM FORMAT I try, I still get the same error.
What do I need to change? What am I doing wrong. I am looking to capture VHS to AVI so I can make SVCDs.
Any better options? I am following the HOW TO section and it says to do this with VDUB and change the VIDEO FORMAT but I am having this problem.
Any help is appreciated.
P.S. You guys have helped me with LOTS of my problems with VCD/SVCD and I REALLY appreciate it. I would be lost without my VCDHELP Connection.![]()
Does anyone have any ideas what I need to do for Vdub to let me change the VIDEO FORMAT?
I am really stuck here.
Any other recommended programs to capture from my VHS via a COMPOSITE input to my AIW 128 NON-PRO card?
Thanks -
From memory 480x480 should be ok. What codec are you using? Some
codecs (esp. hacked ones) have specific frame size rules.
Have you loaded bt87x tweaked drivers???? or are u just
using the vfw drivers that came with the ATI? If so get the tweaked
drivers. -
I don't have any of those drivers. Where do I get them?
So in VDUB do I load a codec first before trying to set a VIDEO FORMAT?
Im mixed up on how to do so.
BIG QUESTION. Would I benefit from purchasing a NEW CAPTURE card that is up to date? This AIW 128 is old by todays standards, could I actually obtain better captures with a newer card?
Virtual Dub: Unable to decompress avc1 file format
By s_joy09 in forum Video ConversionReplies: 29Last Post: 8th Oct 2013, 10:07 -
Video in Virtual dub out of sync
By lituvis in forum Video ConversionReplies: 0Last Post: 7th Mar 2012, 10:56 -
Virtual Dub Mod video combining?
By wcdeich4 in forum EditingReplies: 1Last Post: 18th Dec 2009, 08:18 -
Can I crop in certain sections of video in Virtual Dub Mod
By blackskimask in forum EditingReplies: 15Last Post: 5th Aug 2009, 07:22 -
No Video In Virtual Dub, Just Audio
By AllenM in forum EditingReplies: 11Last Post: 3rd Oct 2008, 14:35
