  1. Hi ! I have a little problem. I have some vcds with concert footage and cause the taper of the concert is very close to some amps the sound is not very good. There are some scenes where it get`s very loud and scratchy etc.
    I want to know if there are any good cleaning or noise reduction programs available !
    It`s very important ! Thanks, Tobbi !
    Feb 2001
    Steinbergs Noise Reduction is a good one, and so is Sonic Foundry's Noise Reduction... I think they are both Direct X effects that'll work in Sound Forge or WaveLab!
    Thanx/
    Lars
    Feb 2001
    Rhode Island, USA
    Yes, I was about to say the same thing. Sonic Foundry Noise Reduction, baby! I have yet to get that, but I use some of their other products,and they're excellent sound people. They parallel in Audio what Adobe does with Imaging and Video technology.
    irc.webmaster.com port 6667 #DDR
