How can i find defect frames with virtual dub and then cut them out.
I need to do this because i always get an floating deciaml point error message in tmpec while converting avi to vcd
try virtualdub with freeze frame detector from
http://www.digital-digest.com/dvd/downloads/virtualdub.html
its a little over half way down the page "vdub_mp3_freeze.zip"
with it load your video then go to the Video menu and select Check Video For Freezes at the bottom
it will make a .log file of bad frames, open it with notepad to see what number the bad frames are
then u should be able to use virtualdub, go to each frame and press delete, then save the movie again with direct stream copy under the video and audio menu
good luck
-Phat J-
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 06:00
