Hey all,
I have been using TMPGenc to convert 25fps AVIs (progressive) to 29.97fps SVCDs (interlaced), and it works very well - video is smooth (no judder). But I would like to try using another tool (like CCE) to encode, and it does not do framerate conversion.
I have seen AviSynth scripts to do NTSC->PAL, but not PAL->NTSC. It seems to me that the right AviSynth script could do conversion of 25fps progressive to 29.97fps progressive or interlaced. Has anyone done this? If so, could you post your script?
(BTW: I have tried playing a 25fps SVCD on my DVD player, and it sort of works, but the audio is out of sync until I move back and forth through chapters. Weird. I would prefer to encode a more-standards compliant NTSC SVCD.)
Thanks very much,
zizou
what are you askin' me for...
I'm an idiot! -
Thanks for the link to Xesdeeni's script. I was able to adapt that script for my uses (25fps progressive to 29.97fps progressive). The key is AviSynth's ChangeFPS function, which simply repeats or drops frames to achieve the requested framerate. And the results looks very good to me: no judder that I can see, same as TMPGEnc results.
Anyone else who wants to try this: note that you do need to use Xesdeeni's kludge to manually lengthen or shorten the video length (frame count) when you change the fps - see his code for comments on this.
Here is my successful script, for anyone to see. Of course, you will need to adapt the resize and AddBorders numbers for your movie:
Code:v0 = avisource("C:\mymovie.avi") v1 = v0.ConvertToYUY2 # When the output frame count is greater than the input frame count, due to # a problem with AVISynth, the output video is truncated so that it only has # as many frames as the input video. Here we work around this issue by # adding enough black frames to ensure all the frames are available on the # output. InputFrameRate = v1.framerate InputFrameCount = v1.framecount OutputFrameCount = round(InputFrameCount * (29.97 / InputFrameRate)) v2 = v1 + v1.Blackness(OutputFrameCount - InputFrameCount) # resize to CVD (352 x 480) with overscan borders v3 = v2.BicubicResize(320,400) v4 = v3.Sharpen(0.3) v5 = v4.AddBorders(16,40,16,40) # change 25fps to 29.97 fps using AviSynth fxn that adds or drops frames v6 = v5.ChangeFPS(29.97) return(v6)
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
IVT with AVISynth of source that has both PAL and NTSC conversions
By csdesigns in forum Video ConversionReplies: 9Last Post: 10th Feb 2009, 13:15 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
