Question 1: What advantage does converting your mpeg files to ac3 have. I have heard that it is very compressed and will give you more space on your dvd's. Is this true?
Question 2: I am capturing with a dazzle dvc2 card using twnh. I am capturing at a maxed bit rate into mpeg 2 using vbr. I am trying to get as close to perfect as possible. I want to be able to produce dvd's of my favorite tv series that are better then VHS. I am caputuring in the svideo input. Is there a better way to capture or better settings? I would like to get 2-4 40mins episodes on one dvd+r disc. Will converting the mp2 audio to ac3 help me with that? Am i using the correct settings for the kind of qualtiy i wont or am i over doing it?
Question 3: If i capture using the seperate audio file option it makes two files one mv2 and mpa. How would i convert the mpa to ac3 and the remerge them? It will not let me load the mv2 file into dvdit pe. Also if i use the normal mp2 file in dvdit and tell it to convert all audio to ac3 it doesn't seem to save me any space.
Thanks for the help..
Paul
Results 1 to 1 of 1
Advantages of using M2TS over .TS with TSmuxerGUI
By jack616 in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2011, 11:35 -
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 20th Jun 2011, 23:56 -
Advantages of ISO?
By hardy in forum Newbie / General discussionsReplies: 6Last Post: 27th Sep 2010, 17:42 -
ac3 filter settings questions
By THX-UltraII in forum AudioReplies: 0Last Post: 11th Feb 2009, 05:32 -
Analog TV-Monitor Advantages?
By therock003 in forum Newbie / General discussionsReplies: 37Last Post: 27th Jan 2009, 16:57
