i converted a divx to svcd then cut it with bbmpeg. then i went to burn it with vcdeasy. when i add the file it shows up as 653mb,but when it actually starts to write it shows up(in the progress bar) as 259 mb? does anyone know how to fix this?
thanks
Under the Tools section of VCDEasy, there is an "Mpeg Scan" function. Run it on your mpg. I'll guess that there is a problem with your mpg somewhere around the 259mb mark, though VCDEasy doesn't inform you of this and simply adds the file anyway
If it finds any error(s), the only way I've been able to fix them is by re-encoding the file again (basically start over from scratch).
Weird (to me) subtitle problem
By alvabass in forum SubtitleReplies: 3Last Post: 31st Dec 2011, 13:50 -
Weird HDMI problem
By WinSpecToR in forum ComputerReplies: 6Last Post: 29th Sep 2010, 04:22 -
weird sd card problem
By fromunda kid in forum Newbie / General discussionsReplies: 8Last Post: 16th Feb 2010, 12:52 -
weird computer problem
By lordhutt in forum ComputerReplies: 5Last Post: 1st Dec 2009, 15:45 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17
