  1. I seem to get a data error in my audio file with DVDit PE. It tells me my data rate is to high and to replace it with a file with a lower data rate. This only occurs in my audio file. Does anyone know of a way i can correct this problem.
  2. Member wesmoc's Avatar
    What method did you use to capture the audio/video? And at what rate is the audio currently?
  3. sorry i should have mentioned that, acutally i was trying to backup a dvd to a dvd-r. I used smartripper and since the file was small enough i didnt have to rencode anything, but i did have to use azid to turn my ac3 file into a wav (dont understand that though because i though DVDit PE could use ac3 files). but when i try to build my dvd i get the error about the data rate.
