thing is i have used other VCDs on my system and they play just fine either with the DVD-rom player or Windows Media Player. its just one VCD that is giving me problems, the funny thing is on a few other systems the VCD in question seems to read okay, in other words...i see the folders, not the 2 music files.
So my question is the VCD in question faulty or is there some quarky set-up i need to change in order for that VCD to be reconized as a "video CD" and not as a "music CD"?
as for the scsi***.vcd file that is fine. has anyone had this problem where some vcds are reconized and some aren't?
thanks.
Are the music files you can see 44bytes big?
And is the disc your reading from a copied disk?
I had this problem with various copied Cd's I tried to open (not just VCD's) with an old drive I had ............ turned out the drive was on its way out.
Cannop -
yea! they are 44bytes and only 2 files. man i hope my dvd drive aint going bad cuz its only like 2 years old...and its a SONY!!!
so when you replaced the drive all your Vcds and other cds worked just fine?
i really hope this isnt the problem.
thanks.
Music Video Vcd Part 2
By vcd4me in forum Video ConversionReplies: 1Last Post: 8th Feb 2010, 14:50 -
Music video vcd
By vcd4me in forum Video ConversionReplies: 11Last Post: 8th Feb 2010, 14:37 -
WMP 10 doesnt play mkv or mp4 files?
By jyeh74 in forum Newbie / General discussionsReplies: 13Last Post: 17th Nov 2009, 11:55 -
HELP! DVD Burning VOB files doesnt work
By liam0114 in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2007, 17:35 -
Newbie that doesnt know much and doesnt know where to put her query.
By emilymeg in forum Newbie / General discussionsReplies: 22Last Post: 10th Jun 2007, 12:46
