  1. Hey Guys I need help, everytme I go into DVDIT and choose to BUILD a dvd folder, it keeps coming back with "Build Failed Unknown Error (-27311)
    I already converted my video file into a dvd compliant file, does anybody know what could be up with it? plz, if anyone knows, I would be greatly appreciated.
  2. I have seen this problem when supplying my own bitmaps/jpegs for menu backgrounds. Read the help/docs etc and check what sizes are best for these. Then ensure your graphics conform to their standards before hitting build.
    You can always try a build with just Sonic supplied images and your mpegs if you want to prove that is the problem first.
    SoCal
    I also got one of those helpful error messages when I had a button on a menu that was referencing an asset that I had removed to try to get the file size down. I removed the video file but forgot to remove the associated menu button. The error message happened almost at the end of the transcoding process.
