I have a video capture card already installed in my pc and would like to hook it up to my VCR to capture some programs from TV that I have on video tape. Now for the question........
According to my manual, the plug that is suppose to hook up to my vcr is an "S plug" , however I do not have one on my vcr (standard video/sound plugs that every VCR has .... red/yellow and black, but no "S plug").
Also according to the packet with the "S plug", it is for video and not audio, so how would I capture sound as well?
Sorry for the questions![]()
Thanks in advance
There are RCA-SVideo adaptors available commercially, although it is quite strange that the manufacturer of your capture card decided not to suply one.
All you need to do is to plug the standard cable from your VCR (SCART-RCA or RCA-RCA) to such adaptor, while the audio part of RCA should be plugged to your sound card (Line In). In case that you want to get stereo audio input, you'll also need a RCA-Phones adaptor, which is also available commercially. The cost of both adaptors is next to nothing, so buying them shouldn't left you with no money in your pockets
Homo Homini Lupus Est. Ipso Factum. -
most capture card have more than one input . one composite and one svhs at least. you need to connect your video out to the composite in on your card, and the sound to your line in, don't forget to set recording properties to line in if you want sound.
Craig :P
DIVX3 on Danelec so easy hdmi ***** newbie question
By fraguil in forum Video ConversionReplies: 2Last Post: 6th Sep 2011, 05:56 -
Easy Question..Make duplicate of movie DVD
By WareISChris36 in forum DVD RippingReplies: 4Last Post: 23rd Jul 2011, 15:43 -
Easy Question.. Convert mkv to DVD9
By WareISChris36 in forum Blu-ray RippingReplies: 1Last Post: 21st Jul 2011, 16:22 -
You Tube Question... (should be easy)
By greenstrat in forum Video Streaming DownloadingReplies: 1Last Post: 20th Jul 2009, 23:47 -
Newbie Roxio easy cd and dvd burning question.
By mmmipa in forum Newbie / General discussionsReplies: 8Last Post: 24th Nov 2007, 22:31
