Hi guys, I have read the guides on this site and they are excellent!!
I have just one query with DVD2AVI. The encoder methods available seem to be either Cinema Craft or TMPG. I have downloaded previously, Divx 5.02. Isn't this a better method of encoding? or how does it compare to the 2 in DVD2AVI?
Sorry if this is a dumb Q, but if you can advise me or put me right, that would be great.
p.s I am (intending, after research) to convert DVD's to VCD or SVCD for playback on my standalone DVD.
One other thing I can't get an answer to from the guides is whether the CVD format be played on a standalone player?
Thanks in advance for your help..
Pete
if you want to play on set top, what you want divx for? cant play divx on set top.
For CVD it depends on the player, you'll have to try it out.
absolute easiest way to convert dvd to svcd is using DVD2SVCD. just a few click for the whole process and it even gives good result.
http://dvd2svcd.doom9.org/Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
Thanks,
I thought DIVX just compressed the file to AVI more so that I could get more on one disk?
So, are the compression / encoding options in DVD2AVI OK for writing VCD then? -
compress using CCE or TMPGEnc for VCD, you can frameserve with DVD2AVI if you want. take a look at the guides, thats what theyr there for
http://www.vcdhelp.com/dvdripping.htm
and
http://www.vcdhelp.com/convert.htmWell, I am the slime from your video.
thanks - makes sense.
But what is DIVx for then - just for maximal compression when watching AVI's on a PC?
If someone can explain this then that will answer all my Q's
Ta. -
as of now, yes. amby some player will support in future.But what is DIVx for then - just for maximal compression when watching AVI's on a PC?Well, I am the slime from your video.
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
Divx Author 1.5 Re-encoding standard divX files
By ejai in forum Authoring (DVD)Replies: 2Last Post: 9th Jul 2008, 20:28 -
Best settings voor TMPG Express MTS Files to Divx Avi
By jeremyotten in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Mar 2008, 10:36 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 12:30 -
DVD authoring and encoding on TMPG and Ulead
By bellyting in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2007, 17:53
