Hi!
Appriciate your support...
I am adding several files to a project, using Roxio Easy CD creator, 5.01.
However, when played back, I can only see the first file. The other files burnt are on the cd (segment directory) but the software can not find them.
I am creating a VCD, and use the wizard.
Is there something known to you other members?
I really would like to add several files, and then (off course) be able to watch them!
Thanks in advance // Fred
Its been a while since I used this program, moved on to Video Pack 5 instead, however if your using the wizard you need to select the movie segments in the left window and put them all into the right, if you miss this bit out you may add them all, but provide no way to play them. Use the wizard carefully and read each screen, you missing something out.
Ah, I still have it installed
Add > Select movie1 > Select PAL/NTSC
Add > Select movie2 > Select PAL/NTSC
Next
Select movies from left hand windows click Add >> to move them across to right -
Hi!
Appriciate your answer, but I have done EXACTLY what you recomend...
I will give Nero a try this weekend, hopefully with better result.
Thanks anyway // Fred -
When you say you can only see the first one, have you let it play to the end to see if the next is played ?
Can Roxio USB capture be used without Roxio's software?
By miamicanes in forum Capturing and VCRReplies: 4Last Post: 18th Oct 2012, 16:30 -
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
Remove multiple tracks from multiple MKV files
By accoutabc in forum Video ConversionReplies: 3Last Post: 7th Aug 2011, 11:50 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28
