I'm just wondering if there is a quick way of getting near 2 pass VBR encoding. Is there a way of taking the output from a Bitrate Viewer log (scanning your VOBs), scaling down the figures and banging the info into CCE (such as convert the log to a VAF file) or TMPGEnc as the desired bitrates to use during encoding? EG Bitrate Viewer shows min 1200, max 9000 avg 6000 -> scale down to min 400, max 3000 avg 2000. Specific EG: at 1:00:01 the bitrate of the VOB is 4803 so at 1:00:01 in the mpg encode use a bitrate of 1601.
This way the time taken would be just a one pass plus the BV scan (very fast).
Just a thought,
Bolix
No it doesnt work like that. Bitrate viewers simply look at the bitrate and the resulting Q value. Some can analyze other aspects of the video as well but nothing like what a multipass mpg encoder does. The first pass of a multipass encode analyzes the actual pictures in your video and determines how the bitrate should be allocated.
The closest thing I can think of to implement your idea is to use 1 pass manual vbr and just go and add or subtract bitrate according to how the source is encoded, as viewed in Bitrate viewer. -
Cheers Adam,
Now I'm not saying you're wrong, I'm just trying to understand this. The bitrate viewer can show you how the bitrate has been allocated in a VOB, so why can't this log be used to determine the bitrate of the encoded mpeg (at lower levels say take log and divide all numbers by 3). Now I realise that the first pass in a VBR must do more than this otherwise it would be a damn sight quicker, but if the bitrate was determined by the bitrate viewer log, then surely you would get half decent encodes - better quality than CBR, more measurable file size than CQ, faster than 2 pass VBR (though probably not quite as good quality).
Bolix
DVD Bitrate Viewer for Mac OS X???
By bendermac in forum MacReplies: 8Last Post: 17th Nov 2011, 08:58 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Minimum Bitrate MPEG2 encoding
By Rob D. in forum ffmpegX general discussionReplies: 4Last Post: 14th Jul 2010, 09:44 -
Looking for FLV bitrate viewer
By kevin3d in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jan 2008, 17:30
