ripped black hawk with smartripper converted w/ dvd2avi/ tmpeg/ to create 2 vcds. My problem is dvd2avi cut video into 2 sections each 1.93 gigs each about an hour long, and the audio into 1 file. iconvertd part 1 i hour and 7 minutes to vcd with no problems but when i loaded the 2nd video file and choose the onlu audio file it converted part 2 video using the sound from one. In other words although i checked the sound file to make sure all 214 minutes were there for some reason tmpeg didnt sync the audio and video. Ant idea how to correct? or is there a avi file joiner so i could just join 2 avi files? Any help would be appreciated. tia shawn
It sounds like you are saving the file as an avi using DVD2AVI, dont let the name mislead you, theres a far better and quicker way to do this especially if your using Tmpeg.
Load your Vob files into DVD2AVI and select your Audio and Video settings, yours will probaly differ but i always use these.
FOR VIDEO
Color Space RGB 24-Bit
YUV>RGB- TV Scale
FOR AUDIO
Track Number One
Dolby Digital Set To Decode
Dolby Surround Downmix
48>44.1khz set to OFF
The go to file ans select SAVE PROJECT, this will create a d2v file and a wav file, DO NOT DELETE the vobs as the d2v file is tiny and is only a link to the vobs, if you save as an avi you end up with at least 2 massive files as Earlier windows file systems cant have files bigger than 2gb.
Load the d2v file into Tmpeg in the video box and the wav in the audio and encode away, all you need to do after that is split it if you need to.
Hope this helps
:P
Black Magic Intensity Pro problem
By jamez_5 in forum CapturingReplies: 3Last Post: 7th Dec 2011, 10:27 -
Black Box Problem
By alimustafakhan in forum SubtitleReplies: 0Last Post: 25th Aug 2010, 07:55 -
black & white only, cables problem?
By majel in forum DVB / IPTVReplies: 1Last Post: 4th Jan 2010, 09:51 -
Black screen with audio in all players except WMP
By charliei in forum Software PlayingReplies: 11Last Post: 8th Jun 2009, 18:42 -
Premiere Pro 7.0 or 1.x problem with green or black frames
By bruce & suzie in forum Authoring (DVD)Replies: 0Last Post: 6th Jan 2008, 11:27
