The cue file I downloaded was invalid. I've never created a cue file so I don't know how to get the correct info from the bin to do so. I have a problem with VCDEasy and TSCV in that they keep giving me blue screens and rebooting my system. (I'm going to reinstall my OS in a few weeks, but for now...). How do I either create a valid cue file so CDRWin can use it or burn the bin directly? I used VCDGear to make it into a dat file and burned that but it looked VERY washed out and not very good. Any help would be appreciated.
Results 1 to 19 of 19
please bear with me
im a newb myself but try extracting the mpeg or dat file from the bin using winrar
hope it works
if you managed to extract the content from the bi the cue wouldn't have made a diff if the video is washed out you downloaded a crappy release
Sorry
Hope that helps#videohelp on dalnet! -
not neccesarily
if you use vcdgear to convert to dat you lose a ton of quality
ive done that myself
if you can just extract the file without any conversion it should look better -
I didn't think so because the rest in the series (by the same person) look fine.
How do I extract it without any conversion? It doesn't seem that WinRAR opens bin files. It says it's not a valid archive. If you've done this, please tell me how. Thanks.
Just answered this one few days ago. The cue file is a simple text file that gives a file path. Open any cue in Notepad, edit the path. If you don't have one, download one or use VCDimager on any mpg and edit the resulting cue as above.
Yes, it CONVERTS the bin to a dat or mpeg and doesn't just extract the mpeg from it. I'll try isobuster and hopefully that won't convert it also.Originally Posted by resnullius
I had programs like notepad and other cue specific editing software but they don't help me to know what exactly I should edit in it. (i.e. what values I put in.) I was looking at my other cues, but they had Flags at different times and I didn't know where these were for the bin I was using. I know HOW to edit it, I just don't know what the values should be for the different tracks (usually two of them).Originally Posted by Nelson37
im sorry i meant isobuster
i was at work when i replied and wasnt thinking
so did it work
just burn the bin as is.
load it in nero or mount it in daemon tools and do a direct copy.
u can see my site for more info.Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
From looking at your website, it seems that both of those choices (Nero, Daemon Tools) need the cue file. They don't seem to give the option to load in just the bin. By the way, still not home yet so I haven't tried the previous suggestion.
hmm might not be clear in the guides, shall take a look at that, thanks. but in the main page for burning it should be. just load the bin instead of a cue in either of them.
If you miss the cue then extract the Mpeg file from the .bin with isobuster and then burn the MPEG on a SVCD, for example with Nero.
SiCN - the real one!
"Dudes, we gotta think here... What would Brian Boitano do?" -
Well, just burning the bin with Nero didn't seem to work, I was using 5.5.8.2 also. So, I'll try isobuster.
It seems you guys were right and it was an inferior rip. Everything I've tried has it coming out a bit washed out and slightly jumpy. Thanks for all the advice and choices though. I actually redownloaded it and figured out what was wrong with the cue and corrected it, but it still came out looking substandard. I have to just find a better quality rip.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
