i'm new to the VCD world - using cyberlink powerdirector with a geforce 4600 vivo card - captured a 2 hour video to mpeg format, but when i try to use nero 5.5.4.0 to make a VCD, it won't fit the 1.2gb file on the CD - from what I hear, there should be some type of compression of the mpeg going on, but I don't know exactly what I'm doing wrong....can somebody tell me what's up, I feel like I'm so close yet so far.......
Your are sooo close
Your mpeg file of 1.2gig is too big. Maximum filesize for
an 80 minute cd is approx 800 megabytes. I suggest you
break your 1.2gig file into half and burn each on one cd.
Check the tools section (on the left) on how to do this. You can use tmpgenc, dvtools etc.
Need help with compression
By dfreeman1971 in forum Authoring (DVD)Replies: 7Last Post: 4th Jun 2010, 02:18 -
Better Compression?
By anirban in forum Video ConversionReplies: 20Last Post: 5th Oct 2008, 18:19 -
Compression
By darts44 in forum Newbie / General discussionsReplies: 7Last Post: 10th Nov 2007, 23:51 -
compression
By m-man in forum Newbie / General discussionsReplies: 5Last Post: 4th Jul 2007, 13:18 -
Compression
By Martig in forum Video ConversionReplies: 2Last Post: 25th May 2007, 22:17
