I just got my Pioneer 104 DVD-RW a couple of days ago and so far have had success backing up one DVD (Bad Boys).
With Bad Boys, I just extracted all the files using DVD Decrypter and used IfoEdit to keep the main movie. The movie was able to fit easily on the DVDRW and plays in PowerDVD. I'm thinking this is easier than I thought.
Next day I get A Beautiful Mind and Musketeer. Easy stops here.
Looks like A Beautiful Mind is too long to just extract the main movie and burn, so I think I'll have to use Rempeg to downsample.
The Musketeer is only 105 minutes so I figure this should be no different than Bad Boys which is 119 minutes. First I copy all the files from the DVD to the HD and try to use IfoEdit. The main movie still came out too big to fit on a DVDR. Are some movies encoded at a higher bitrate than others? Would this explain why one 119 minute movie can fit on a DVDR while a 105 minute movie can't?
I've decided to try and Rempeg The Musketeer, but on my P3 866mhz it's reporting that it'll take 28 hours!![]()
Does this time sound right to you guys?
A friend lent me his Matrox RT2500 and I was wondering if this could be used to re-encode the files to fit?
Thanks for any information
i have heard that rempeg is not so good, have not tried thou.
I assume you striped the movie from un unseful stuff first? (extra sound and so)
www.dvd2dvdr.com might helpWell, I am the slime from your video.
Oozin' along on your livin'room floor. -
Ya, I used Smart Ripper to stream process just the main movie to a m2v and the 5.1 english track. I'm following the guide that's on www.dvd2dvdr.com. Do you know of any other alternatives to rempeg? Are there any guides to using LSX or CCE to re-encode for a DVD compliant stream?
i dont know of any guides sorry, and i will not get a dvd-r and make one my self for a month.
take a look inthe how to section here or at doom9.org. there may be something.Well, I am the slime from your video.
couple newbie questions - DVD to MKV and watch on WDTV
By timmyinnis in forum Newbie / General discussionsReplies: 7Last Post: 26th Apr 2010, 03:14 -
a couple of sub questions
By Kanyeeeze in forum SubtitleReplies: 1Last Post: 1st May 2008, 17:03 -
A couple of general newbie questions
By serpetary in forum SubtitleReplies: 5Last Post: 21st Mar 2008, 11:01 -
a couple of questions ..
By ZaYoOoD in forum AudioReplies: 6Last Post: 7th Mar 2008, 14:21 -
couple questions
By mainegate in forum ffmpegX general discussionReplies: 2Last Post: 31st Aug 2007, 11:22
