I have looked at the guide here at vcdhelp, however, I am a newbie, so some things I have got to ask anyway. The SVCDs that I want to make into VCDs are already burned to disks and I have thrown out the files. Do I have to take the files from the disk and put them back in the computer to be able to work with them? Sorry if this sounds like a stupid question, but cmon guys, help me out! If I did not phrase this question correctly, please let me know and I will try again. Thanks to all that respond.
budgirl357
Yes- just copy the "AVSEQxx.DAT" file in the (I think) MPEGAV folder on the SVCD- you might have to rename it AVSEQxx.MPG in order for TMPGenc to use it (not really sure....).
So you mean copy the AVSEQxx.DAT file (found in the MPEGAV folder) to a directory, and it will contain all the data that I need to make the conversion? Also, thanks for the help Gargoyle, very quick of you!
Peace,
budgirl357 -
Surely you are talking about a .mpg file rather than a .dat file for SVCD?
Why, is there no DAT file found in SVCD? So I should look for the mpg file within the mpegav folder? So when I find the mpg file (in the folder) what do I do with it? Do I save it in the directory of my choice for later retrieval? Or am I supposed to take it straight from the mpegav folder and load it into a certain program? I read somewhere that I should check for errors in the file when performing this process. Please answer asap if possible, thanks for all the help so far1
Thanks,
budgirl357
mil0tis guide question
By extrafuzzyllama in forum Blu-ray RippingReplies: 9Last Post: 25th Sep 2011, 21:03 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
Asafs TV Episodes to VCD-DVD guide
By angelheart in forum User guidesReplies: 4Last Post: 19th May 2008, 20:47 -
Patching SVCD to DVD question
By zanos in forum Authoring (DVD)Replies: 22Last Post: 29th Jun 2007, 09:17
