  1. Hi guys.
    I had TMPGenc & Plus 2.53 on my PC, and both worked fine, let me edit files (top & tail), demux, etc.
    I downloaded Plus 2.55, and when I ran it it said the trial period had ended already, so I just removed it. However, since then, I can't do anything in TMPGenc. It runs OK, and pretends to do things, but once I set it doing something (demux, for example), it just hangs and doesn't do anything.
    I'm thinking that maybe 2.55 has seen the earlier version and buggered them up. Is there anyway I can clean them up?
    Canada
    I got some probleme like that Mine worked fine now when i do svcd to vcd my sound is delayed
    Canada
    Am doing a test i just installed it on my secondary PC it's VIRGIN in codec but running XP
    so i installed PowerDvd and Tmpgenc .. and now testing it , It dint fuckedup like it did with my win2k ... it's wierd coz it's the same version
