When converting a divx to a xvcd can you match the resolution in tmpgenc? Will it work ok?
Currently I either use normal NTSC res or 480*480, im just curious if theres anything stopping me from using the same res as the divx.
It all depends on how you intend to use the end product.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Resolution Question
By killerteengohan in forum DVD RippingReplies: 14Last Post: 9th Aug 2011, 22:00 -
PC to TV screen resolution question
By majel in forum DVB / IPTVReplies: 15Last Post: 28th Jun 2010, 10:22 -
Video Resolution Question
By mohawkcr in forum Video ConversionReplies: 10Last Post: 22nd Apr 2010, 21:40 -
Newbie question about resolution and quality
By Sutekh in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2009, 18:01 -
DLP Resolution Question ?????
By ofield1 in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2008, 19:44
