ok, i found that when i attempt to record an ntsc svcd onto a pal vhs its black and white and has no sound. So i tried converting the svcd into a pal version but it came out wrong. Is there any simpler way to get this svcd onto a pal vhs without doing the long way of converting the svcd from ntsc into pal then recording?
thanks for any help
Yes.
See the How To section on using tmpgenc.
Using Tmpgenc, open up the movie file from
your cd. Load up a standard NTSC or PAL template
(whichever u want to convert to) and output as a mpeg file.
Make sure motion search precison setting is set to very high.
If the above does not give pleasing results, you are
going to have to learn about frame rates, as well
as v.dub or avisynth and possibly audio software
like b-sweet.
You can make perfect transfers between NTSC -> PAL
and vice versa but often it needs a little bit of art as well
as science. -
OR...Get yourself a PAL/NTSC DVD player and you can
switch between both formats as u please.
OR.. hire yourself a PAL/NTSC transcoder
whats a PAL/NTSC transcoder?Originally Posted by offline
I have a PAL/NTSC DVD player, but it still record's as black and white when i switch formats.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
Determining Whether a VHS is NTSC or PAL
By innocenceisdeath in forum RestorationReplies: 5Last Post: 28th Jun 2010, 04:45 -
Convert PAL to NTSC VHS?
By manhnt in forum Newbie / General discussionsReplies: 4Last Post: 29th Jul 2009, 15:49 -
Pal S-VHS to NTSC PC
By Jerry1964 in forum Capturing and VCRReplies: 14Last Post: 19th Aug 2008, 09:50
