I recently discovered all of this VCD and was so excited so i wanted to put my simpsons collection (mostly in avi) on a vcd or svcd, but tmpg cannot open any of my avi files, though they play through windows media player just fine, i have gotten plugins, changed priorities, any suggestions??
Thanks in Advance
What version of Tmpeg have you got and whats the error message?
Can you open them in VirtualDub? -
I got it to work with avi2vcd, but i have the newest version of tmpg, and it says cannot open or unsupported or something there about. Thanks in Advance
heres how you fix that
go into option->envireromential setting->vfapi plug-in
ok as soon as you are there heres what fixes it
click on directshow miltimedia file reader and right click on it and select higher priority until you get to +3 not negative three.
then go to avi vfw compatibility reader do the same thing to this but raise it to +2
then unclick avi2(opendml) file reader
then push ok and load your file then it works dont you love me it took me a while to get the right answer so im glad you finally got the right answer!
have fun man its awesome when it works
-mike
Converting Avi to Mpg using ffmpeg
By sumit_pankaj in forum Video ConversionReplies: 5Last Post: 31st May 2020, 21:42 -
Aegisub wont play mpg, converting using divxland causes problems
By denadel in forum SubtitleReplies: 2Last Post: 2nd Oct 2011, 05:36 -
converting flv to avi/mpg
By nimrodm in forum Video ConversionReplies: 1Last Post: 14th Feb 2010, 08:05 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 22:18 -
Problem converting from .AVI or .MPG -> DVD
By ConaHead in forum Video ConversionReplies: 9Last Post: 15th May 2007, 23:13
