Hi all, PC running XP, with Pioneer A04 burner and Pinnacle Studio 7 Deluxe with digital/analog capture card.
The problem is that each time I load a piece of burning software (ie. Nero or Roxio CD Creator) I am losing access to my A04 Burner. Nero refused to see it as a drive. Roxio CD creator when loaded sees it fine and burns ok but then it somehow removed the A04 drive from within DVDit. When I loaded Nero it also removed visibility of the analog input function on my capture card, only the digital input was available. That required a re-install of Studio 7 to get it back. The only way I could get the drive visibility back for DVDit was to remove Roxio, uninstall DVDit and then re-install it.
What the hell is going on?
Results 1 to 1 of 1
What free software for down loading YOU TUBE videos for best quality..
By gary153 in forum Newbie / General discussionsReplies: 8Last Post: 3rd Nov 2010, 08:47 -
losing audio when loading into vid editor..
By krohm in forum EditingReplies: 26Last Post: 24th May 2010, 08:41 -
Question how to make software use D drive instead of C drive
By jimdagys in forum ComputerReplies: 9Last Post: 28th Sep 2009, 01:38 -
Loading extra codecs into media drive
By Dzuma in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2009, 18:30 -
losing subtitles when burning with Toast
By mmax102 in forum ffmpegX general discussionReplies: 3Last Post: 2nd Nov 2008, 08:34
