Now that I've gotten the hang of making vcds I now want to burn all the mp3s that I have on my computer to cd since my dvd player will play them.
Someone told me that mp3s take up less space so you can fit more music on a 80min 700 mg cd,
I've made 2 cd's but could only get an average of 20 tracks on the cd these are all mp3s I go to my mp3 folder with nero drop and drag the mp3s I want on the cd and thats it they play fine but am wondering about the size issue thought I could put alot more on the cd with mp3s
Am new at this so if someone can help great thanks.![]()
I Don't know at what quality you made your MP3's, but if you use the typical Stereo, 128kbps, then you can put around 170 songs on a 74min CDR media which would equal to about over 11 hours / near 12 hours of CD Quality Audio.
I've done about 5 or 6 of those by now using Audio Catalyst (to create) and Nero (to burn).Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
make sure you are burning them as data cd's, if you burn them as audio cd's you will not get alot on the disc
As tenders mentioned, if you burn MP3's as Audio CD's, it will basicly be converted again to Audio CD, so you'd be limited to 74min Audio for 74min CD.
Best Regards,
Sefy Levy,
also I've only been able to play MP3-Cd's if I burnt them as No Multisession
and finilized the disk.
Burrrn and MP3s
By Fantome in forum AudioReplies: 7Last Post: 16th Dec 2010, 11:25 -
Selling your MP3s?
By Dr.Gee in forum Off topicReplies: 4Last Post: 31st Jan 2009, 15:31 -
mixing 2 mp3s together
By motleycool in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2009, 10:04 -
mp3s to a dvd
By AeR0 in forum AudioReplies: 8Last Post: 2nd Aug 2008, 17:48 -
Make volume same for several MP3s
By vjdnld in forum AudioReplies: 9Last Post: 1st May 2008, 10:39
