Hey y'all . . .
Have a question concerning the standard (?) VCD format. At present, I capture old VHS videos to MPEG2 using PowerVCRII, clean them up using EasyEdit and convert to VCD using TmpgEnc.
I convert to VCD primarily because of file size issues - the default PAL VCD image size appears to be 352 x 288.
Has anyone else had consistent, good-quality output using any other video image size? I'm aware of some of the other TmpgEnc templates available on this site, but some of them won't work with my dvd player (a Teac 2150).
Thanks in advance,
B.
Sorry - should also add that I'd like to keep using the VCD format if possible.
B. -
Read this:
http://www.vcdhelp.com/vcd.htm
It lists the compliant VideoCD resolutions (and other specs) for both PAL and NTSC.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
DV-AVI / Format size
By willmington in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2011, 10:49 -
How to size down MTS video format?
By khan.cross in forum EditingReplies: 1Last Post: 9th Aug 2010, 10:07 -
Best video format irregardless of size.
By laithmeister in forum DVD RippingReplies: 7Last Post: 25th Jan 2010, 14:38 -
MP3 format size
By coody in forum AudioReplies: 9Last Post: 18th Jun 2008, 09:45
