OK I encoded a CVD that I was very pleased with a couple of days ago.
My PC crashes and I end up re-installing my pervious image. I then install TMPGEnc 2.56 (I was previously using 2.54). I try to re-encode the CVD from the exact same source using the same template and I don't seem to be able to achieve the same Quality as what I encoded a couple of days ago and its driving me nuts
I need to analyze the original file, what program can I use to do this any thoughts?
Regards
Amelia
Results 1 to 11 of 11
If it's playable on Window's Media Player, right click -> Properties->Advanced->MPEG Video Decoder->Properties. You will retrieve the bit-rate info. As for the GOP structure, not sure how to analyse. Anyone?
you could use bitrate viewer
http://www.vcdhelp.com/tools.htm#other -
Thanks for the link
I went to the link http://teco.emg.hu/bitratev/BV.EXE but unfortunately I get an 404 error (file not on server).
Anyone have a copy?
Best Regards
Amelia -
Truman,
That's the link I used, but when you click to download, you are taken to:
Its a dead link.
dvdpatcher is a nice utility that also provides info about the mpeg stream.
http://kickme.to/DVDPatcher -
Thanks zeppage2,
I am going to download it now. Hopefully I can get to the bottom of this mystery.
Regards
Amelia
How to analyze video files for corruption
By TomLJ in forum Newbie / General discussionsReplies: 0Last Post: 11th Oct 2009, 14:36 -
How to fix MPEG encoded with wrong aspect ratio?
By Talayero in forum Video ConversionReplies: 2Last Post: 21st Oct 2008, 09:29 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 18:55 -
Analyze WMV
By vegasarian in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2007, 04:16 -
Software to analyze a DVD?
By kristian1 in forum Newbie / General discussionsReplies: 4Last Post: 8th May 2007, 13:12
