Anyone interested in working with me on creating an open source AV system.
The intent is to create a system with the following base features
Software:
Compression-MPEG1/2/4
Decoding- MPEG1/2/4
Real time MEPG1/2 encoding
Real time MPEG1/2/4 decoding
Simultaneous MPEG2 encode decode (PVR)
Non-windows OS
OpenGL compatible for gaming
Hardware:
Athlon CPU 1500+
256 meg DDR
CD-RW drive
DVD drive
40 gig hard drive
3D graphics card
TV out(S-Video and composite), SVGA
Form factor:
Must fit in space of normal AV component
1 set AV inputs front and back
1394 front and back
Operator interface
Remote control
Anyone interested let me know your ideas and lets get started.
No matter where you go, there you are.
Well hopefully it will not be as much work as it sounds like at first glance.
The plan I have in mind is to use a Linix OS variant. Some claim to be able to support windows programs.
Then the standard bundled playback software with the DVD
DVD DVDR CD VCD SVCD Photodisk
Then the standard bundled recording software with the CD-RW
audio CD, VCD, SVCD, XSVCD
Add a Graphics (either card or built into the mother board) with it TV in and out bundled software
PVR and 3D gaming.
Then the freeware and shareware can provide the following features.
Divx MPEG4 compression and playback
VCDeasy VCD SVCD etc
virtualdub1394 DV capture editing and recording
MP3 stuff
Most of the software work will be checking compatibility, taking care of instant power on and working out the user interface issues.
Finding the correct format box to put it all in a AV slot will probably be a big issue.
If anyone has feedback I would be glad to start listening.No matter where you go, there you are. -
I just ran across a chip announced in EE times today that claims to do real time compression and decompression of MPEG1,2,4. It is suppose to off load the work from the PC at a bargain basement price. They claim that they have drivers for multiple OS. What I don’t know is what the quality is really suppose to be. Can someone look at their data sheet and give me some feedback. Here is the link to the data sheet
http://www.wischip.com/graphics/WISGO7007_F.pdf
And here is the link to their site
h
Here is my systems requirements question of the day. Do we need a TV tuner in the system or can we get along without it.No matter where you go, there you are. -
Here is my first shot at the case outline.
www.nitchville.com/case.htm
Let me know what you think should be changed.No matter where you go, there you are. -
It looks like Lindows will work for the OS. It looks to have all the supporting software that is needed. I will continue checking for compatibility issues. Please look them over at www.lindows.com
I have found one mother board in the flex ATX form factor that lools like it might work. I do not know if the built in graphics is good enough. I have posted the mother board spec at
http://www.nitchville.com/shuttle%20fs40.htm
I will try and get all the information structured and published in the near future until then please just use the links in the messages.
Please give me some feedback on the OS and the graphics/No matter where you go, there you are.
Best open source NLE software
By landstake in forum EditingReplies: 42Last Post: 24th Jun 2012, 01:09 -
any open source vReveal alternatives?
By deadrats in forum ComputerReplies: 2Last Post: 12th Oct 2009, 08:16 -
Do you donate to open source software?
By yoda313 in forum PollsReplies: 15Last Post: 28th Aug 2009, 20:15 -
Open Source authoring tools
By lmemsm in forum Authoring (Blu-ray)Replies: 2Last Post: 8th Jul 2008, 12:20 -
A proposal for Open Source HD-DVD
By hddvdrebel in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th Mar 2008, 22:12
