I know that regular svcd and vcd files can be up to 80 mins long to fit onto a single 80min CD, regardless of the files size.
But what is the go with a .bin file that holds a SVCD or a VCD? I have to convert the .mpg files to .bim with VCDEasy to be able to add chapters as my burner is not supported by VCDEasy. Does this mean that I can no longer fit 80mins (say file size of 750 meg) on a single 700MB-80min CD because the file will not be burnt in SVCD or VCD. Or does it not matter as it still is a VCD or SVCD.
Adding the chapters adds very little size to the original file so if it fitted in the first place and a .bin file can still be 80mins then it will still fit.
No, the CUE/BIN is just the disc image.
It's not going to affect the "size" of the MPEG file you are going to put on a S/VCD.
Regards.Michael Tam
w: Morsels of Evidence -
Sorry just so i got it right, a 750 mb (Say 75min ) Svcd .bin file is okay for a 700MB 80 min CD?
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
Burning a CD -- Minutes vs. File Size
By Opv in forum AudioReplies: 17Last Post: 5th Mar 2011, 23:55 -
Is there a max file size when Joining avi files.
By admjim in forum ffmpegX general discussionReplies: 2Last Post: 14th Feb 2010, 04:41 -
Wrong File Size on Ripped Files using AutoGK
By tommyjv in forum DVD RippingReplies: 4Last Post: 17th Nov 2008, 13:21 -
Question about burning file size
By magikero01 in forum Newbie / General discussionsReplies: 7Last Post: 3rd Jan 2008, 08:34
