@homerpez
Try Office Depot, I believe that's where I bought mine.
Results 31 to 34 of 34
Ok, correct me if i'm wrong but, if data is read incorrectly from an ANALOGUE source say, an LP or VHS tape the sound or picture quality degrades. Data held on a CD/DVD is DIGITAL if it is read correctly then OK, if it isn't then you get nothing or just a audio/visual mess, am I right?
That's pretty much what happens, except that the info on a VCD can be read PARTIALLY, and suddenly go blocky/nuts (because it's unable to read info from several frames before or after). That's the problem I noticed on mine. They were fine before labels, and not after.
I've also had this happen when you stumble across one bad CD-R, same thing except I guet a "rainbow" like effect when this happens, like the blocks had random solid colors to them. On the label problem, it would keep displaying info from several frames back, while it changed the blocks it could read (very strange). -
My father in-law got me a pack of 300 labels (thats 150 sheets) for $20 U.S. at Sam's Club (a warehouse store) which is a part of walmart. Talk about a smoking deal. And yes these were the NeatO labels.
<font size=-1>[ This Message was edited by: vanillabox on 2001-08-10 14:36:09 ]</font>
iMovie - Importing time : Does a hint exist?
By iwiiiiiiiiii in forum MacReplies: 4Last Post: 21st Sep 2011, 17:31 -
Working with VOB2MPG: speed issue hint
By cdgmol in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 31st Jul 2009, 17:57 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
Hint for deciding on a camcorder
By renshaw8 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 1st Jun 2009, 14:24 -
Creating video files larger than 1 GB with mencoder, important hint
By penguin74 in forum LinuxReplies: 1Last Post: 4th Nov 2007, 20:13
