Hi,
When using Smartripper I get the error message that there is no ASPI access to my dvd-rom drive and that the program cannot unlock the drive.
I have windows XP pro and a Toshiba SD M1212 6x/32x dvd-rom. I am also using 4.71 aspi using the link from vcd help.
Do I need different software, or do I need to do upgrade the firmware for my dvd-rom??
Thanks for the help
1st play the movie for a little bit using your software DVD
player & this should unlock the disc ready for smartripper.
As for ASPI, you should install forceASPI drivers (see tools section)
as the Adaptec release is bug city.
ASPI for XP x64
By HartsVideo in forum Video ConversionReplies: 12Last Post: 6th Jul 2008, 04:20
