I have this CUE and BIN file. I know I have to burn them to use them. I followed the directions on the site (http://www.vcdhelp.com/nerobin.htm) but it says "Stimulating Error" or something like that.
How do I fix it and what do I after I burned the CUE file? Thanks for any help![]()
What is the exact error you are getting?
Where did your CUE/BIN image come from?
Have you tried another program for burning CUE/BIN images (e.g., CDRWin, VCDEasy / CDRDAO, etc.)?
As for what you do after you've burnt the CUE/BIN image properly, you should check the disc to make sure that everything burnt correctly and if you don't have another other use for the CUE/BIN file, then delete it...
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
