I'm trying to burn my first VCD, and have run into a strange problem. I'm using TMPGEnc to create the mpeg files from MOVs, then VCDEasy with CDRDAO to author and burn. After tinkering around I got it to work, all the way up to the actual burning process. Actually, the burning process seems to run just fine... it creates the files, goes through the motions of burning, even the light on my burner flashes, and everything looks like it's working fine... But once finished, I remove the disc and nothing has been burned on it, it's completely blank! Does anyone know what is going on? It's not my burner, as I can still burn audio CDs with my usual burning program (which unfortunately won't do video). Help!
-eric-
He He...
In the main page of VCDeasy uncheck the "simulate" button.
Man I hated when that happened to me......
not just with VCDeasy either....
Hope this helps......
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 11:59 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
